I have tested multiple esp32 ( Nodemcu and DEVKITV1) running wled 0.13.0-b4 .First thing I do is a fresh install of wled 0.13.0-b4 , I only change wifi setting to connect to my home network then :
Go under Config → Time & Macros -->Clock –Clock Overlay -->Analog Clock ( then save )
MCU will go into unrecoverable crash , rebooting or powering down MCU does not work and it will loop rebooting with the below message ( viewed via usb esphome-flasher ) . The only solution to recover the MCU was to re-flash it again . I tried this 3 time and result is the same
Can someone test on the same version and confirm ? please test only if you are willing to re-flash the MCU .Because the environment i tested with is not production i just wanted to confirm if this is a
known issue . If this is a known issue then please just send link
There is an error for cpu panic :
Guru Meditation Error: Core 1 panic’ed (IntegerDivideByZero). Exception was unhandled.
below is repeated so i only attached one page of it
