Critique Me, Is this the right direction?
So jumping straight into WLED with a first big project, done a fair bit of reading but need some assurance before I spend too much money on something that isn’t gonna work.
Its a two part system, Permanent all year section (Red) and a season Christmas section (Blue), figure about 250-300, 12v 3 led pixels per section total 500-600 pixels.
Plan was to have two separate ESP32 controllers (one permanent and one seasonal) with 20-25 amp power source each.
Could I get away with Quin-Led Octa and just change the programming every time I add/remove the seasonal section? (I know I don’t need the channels but its got the power!)
I thought I read about slaving a ESP32 off a master ESP32 to keep the programming in order? but cant find that exact article.
I guess my main concern is going to be the issue of changing the programming when add/removing the second section.
also is dat a injection in the middle of a segment an issue?
let me know what Im doing wrong.
You didn’t state a specific problem but several concerns. Your concerns are justified. You should be able to get the power consumption data from your LED Data Sheet. Regarding ‘Year Round’ vs ‘Holiday’ settings you should be able to make your Effects > Save them as Presets > and build a ‘Playlist’ from your Presets for each, giving them different names so you know which is which, on one ESP32.
Building the year-round and seasonal sections as separate presets and playlists on one ESP32 makes sense, and it removes the need to rewrite patterns each time you add or pull the seasonal run. For the second controller, WLED’s sync feature can mirror a master over WiFi, so investigate that before committing to a dual setup. On the Octa, confirm it meets your 20–25 A budget per section; having channels you don’t use is fine, but headroom matters more. Mid-segment data injection is generally workable with proper power injection and keeping runs reasonable, though test it in a small mockup first.
