Is it possible to have the follow led amounts on two pinouts so that they run as a pair but at different lengths?
Example Pin D2 1 to 200 leds
Pin D4 1 to 300 leds
At the moment when I set a second output the led count continues from the first output as if it were a single length. i.e. Pin D2 1 to 200 then Pin D4 200 onwards.
From the main GUI screen expand segment 0 and make it the length you want click the Check to save it. Click add segment and enter in the length of the second and click the Check to save it.
Thanks for the reply however that didn’t quite work. I had to make two segments as you suggested however the led count had to match the hardware setup page as per the two output pins. Also the “Make a segment for each output” box had to be checked.
Many thanks for guiding me in the right direction.
