I use Eps 32 and there are 15 meters 60leds, I want to control Eps 32 from a single device, I installed the pins, I appointed which pin I installed from the Wled application, but it works differently.
Two lane leds, for example, when I connect Eps 32 pin 17,18, the led is short circuit, what should I do, I want to check a few leds from one device.
It is said that I will be able to control many leds with Eps 32.
So briefly Eps 32 15 meters 60/leds DC5V WS2812B how can I check my LED Eps 32 Thank you for your help
As can be seen in the video, I tried it with 10 meters, I connected it 17.18, it worked unstable and shorted it shorted.
Video link Gofile - Free file sharing and storage platform
wiring diagram picture : s75kny4.png
