I’m not familiar with the ‘curtain’ you’re working with. Are those RGB pixels? You must clearly identify your pixels in the WLED >Config >LED/Hardware menu. If you have three wires on your curtain (V+, GND, and DATA), look at the DATA line between the last pixel that is functioning and the next pixel that is not (barely) functioning.
If you don’t find a bad/loose connection try scaling back to fewer pixels. Try and light just 10.
Hi! The curtain has a main string on top and 20 fairy light strands hanging down, with 20 LEDs on each strand. It forms a 20x20 matrix, but on the button it hangs free. I think they are WS2812B adressable LEDs.
I didn’t open the little white boxes on the upper side on the main string, but I think inside there are small electronic chips as described in several other threads.
I guess those are the reason of the malfunction, and I was wandering if someone else here has come across this problem. The original controller was driven by the surplus app. Maybe there is a workaround that I didn’t find!
Since you suspect the white boxes hold buffer/driver chips, the flicker on strands after the first one fits a data-signal problem rather than a pixel-type problem. Try cutting the configured LED count down to just the first strand (20) and see if it stays stable; if it does, raise it in increments to find where it breaks. Also confirm the data line runs from the controller into the first box, and try a level shifter or a short ground between controller and curtain. Selecting ATA016 likely set the wrong chipset, which could explain the all-white lockup.
The surplife curtain typically uses a fixed controller with proprietary app control, so WLED won’t drive it unless you rewire the strips to an ESP32 and map the data lines yourself. The main snag is that these curtains often run parallel data channels per drop, which a single ESP32 pin can’t handle without splitting segments across multiple GPIOs. Before flashing anything, check whether the controller outputs standard WS2812 data or something custom. If it’s standard, a multichannel ESP32 setup can work; if not, expect to replace the controller entirely.
I don’t know why the posts were flagged and hidden, but thank you anyway for your advices!
@nicholasseward I have already tried to cut down the number of the LEDs: the first 20 are stable, everything after that (and therefore after the first white box) is rebeleus. The very first strand is controlled directly by the controller. The first box comes after the first strand. I tried to add a sacrificial LED a few centimiters after the controller and the first LED of the first strand and set “ignore the first LED” on WLED, but it didin’t help.
@jenniferlewis Maybe I’m a little too noob to follow your instructions I already cut and replaced the original controller with a Gledopto GL-C-015WL. On the WLED app I set WS2812B as output. Anything else I tried didn’t work.
@rustywillow718 Sorry but I’m not able to open the link you attached! Can you summon up some useful experience of your part?
The flagged posts make it hard to follow what was actually compared, so I can only speak to the general approach. A curtain built around WLED gives you local control, an active community, and predictable behavior when your network changes. Prebuilt options can be quicker to hang but tend to lock you into their app and schedule. Whichever you pick, check the pixel density and how the power injection is handled, since that matters more than the controller for a curtain this size.
