Hi everyone,
This is my very first WLED project, and overall I’m super thrilled with how it turned out! It was definitely a steep learning curve—I managed to fry two bare ESP boards early on while wiring, which led me to upgrade my setup with an Elite 6D board / dedicated level shifter to get proper clean logic signals and stable power delivery.
Everything is up and running now, but before I call it 100% complete, I need some guidance on two final calibration hurdles:
1. Main Issue: Edge Overshoot & Trailing Light on Sweep Patterns
When watching movies, the ambient backlight looks awesome. But on high-contrast geometric edge test patterns (like a rotating bar or moving box):
Leading/Overshoot: When a moving bar hits the edge of the frame, the LEDs illuminate slightly ahead onto the adjacent rail before the beam actually reaches it.
Trailing / Walk-Away Delay: When the bright beam sweeps away from an edge into darkness, the LEDs linger for a split second before cutting off to true black instead of snapping off cleanly.
2. Secondary Issue: Orange Diode Color Accuracy
On color wheel tests, warm amber and orange tones on screen trigger pure crimson red behind the frame, skipping the orange transition entirely. (My strips are Natural White SK6812).
My Hardware Setup
Display: 120" Fixed Frame Projector Screen
Processing: Raspberry Pi 4 running HyperHDR
Controller: ESP32 running WLED (communicating via DDP / UDP port 4048)
Capture Pipeline: HDMI 2.1 splitter downscaling to an MS2130 USB capture card (/dev/video0)
LED Strip: SK6812 RGBW 5V (Natural White, ~4000K)
LED Count: 503 LEDs total (Top: 161, Bottom: 159, Left: 92, Right: 91)
Power Supply: 5V 60A (300W) Mean Well-style PSU with inline fuses, running power injection at the start, midpoint corners, and end (no noticeable voltage drops).
Current Software Settings
HyperHDR Grabber: 720p @ 60fps MJPEG, Hue = 1 (to bypass the driver 0-default quirk), Saturation ~110, Contrast ~120
HyperHDR Layout: 4% depth, 0% overlap, 1% corner gaps
HyperHDR Smoothing: Time 20–30 ms, Update frequency 50–60 Hz, Anti-flicker OFF, Min backlight level 0.0
WLED Config: Transition Time set to 0 ms, Realtime timeout 2s
Gif Image nytisqjj - Free Image Hosting | ImgShare
Since this is my first build, I’m really happy with how much progress I’ve made, but I want to nail down these final adjustments. Would this edge overshoot and lingering light be caused by DDP packet handling over Wi-Fi, internal interpolator curves, or something specific in how WLED handles SK6812 RGBW channels?
Any advice from the pros would be hugely appreciated!
