HUB75 with 8 Panels (256x64)?
Hello,
I have a Waveshare ESP32-S3-RGB-Matrix hooked up to 8 P5 panels (64x32). I’m trying to setup a 256x64 panel, but I’m hitting a 4 panel limit. Is there a different way to setup the LED Outputs?
Any help?
The 4-panel limit is most likely the WLED HUB75 driver’s own cap rather than a wiring issue: the I2S/LCD DMA driver on the S3 pushes one chain, and the matrix config in LED Preferences only lets you chain a limited number of panels per output. Try setting panel width 64 and height 32 with the chain length you need, then check Config > 2D Configuration for the panel layout, since 256x64 as 4x2 may be accepted there even if the output page caps the chain. Also note that 8 panels at 64x32 is 16k pixels, which will use a lot of RAM on the S3 and cap your refresh rate, so lowering color depth or bit depth in the HUB75 settings may be needed. If it still refuses, it is worth opening a GitHub issue with your WLED version and the board’s pinout.
FYI I’ve made several improvements over upstream version in my fork regarding Hub75 panels.
The maximum dimensions (and number of chained panels) depend only on available RAM, not wiring.
yes, 256x64 is supported as 2h(orizontal) 128x64 or 4h(orizontal) 64x64 or 4x2 64x32 panels (configuration as seen in my fork). If you want to try it, my fork is available as precompiled binaries on unofficial installer https://wled-install.github.io or CI builds on Github.
You also don’t need special binary for different controller boards as almost all known Hub75 controllers are built-in. With S3 boards you do need to make sure you select correct PSRAM/flash configuration (QSPI/OPI) as otherwise the chip will not boot.
Examples:
Thanks, I’ll give it a shot.
I flashed the nightly build, but I can’t connect to Wifi.
Is this the correct one for the Waveshare ESP32-S3-RGB-Matrix?
I think the correct S3 binary has to have WROOM2 in name. However, I do not maintain the installer so it may be best to ask Wladi which one is best suited for OPI (flash) / OPI (PSRAM) chips.
If you can build yourself (using MS VSC + PlatformIO) the provided environment esp32S3_wroom2 is the one to use.
