Is a dual core ESP32 necessary for totally smooth effects?
I’m using one ESP32 with 90 WS281x RGB compatible chips. Previously, I was using an ESP32-C3. That worked, but effects sometimes glitched. This seemed to be LEDs occasionally flash white on ESP32 C3 SuperMini · Issue #5371 · wled/WLED · GitHub
After switching to an ESP32 WROVER, the glitches are gone. But also, effects seem smoother overall. It seems like with the C3 effects were slowing down and/or dropping in frame rate sometimes, and now that is not happening.
So, I’m wondering, is a dual core ESP32 necessary for smooth effects, because otherwise the CPU time taken up by WiFi makes effects less smooth?
yes and no, depends on your wifi traffic. I have several C3 and they run perfectly smooth but then again I do not use any HA or other tools to constantly poll them, which is what causes the glitches on single core ESPs.
I connect mine with HA. I didn’t realize it could be so disruptive.
HA can be quite aggressive in polling devices for their status
yes, Establishing a Wi-Fi connection can add a fair load to a MCU.
I have no idea what use WLED firmare makes of the second (low power) processor if it’s available.
Consider also the MCU’s frequency (speed). ESP32-C3 uses a 160MHz processor. I haven’t used a plain ESP32, but I suspect newer versions support higher clock speeds.
FWIW, I personally use an ESP32-S3 with 240MHz clock and linked to HA - currently driving one chain of 4 x 16 x 16 LED panels = 1024 LEDs from one GPIO pin (yes that’s more than WLED recommends) but results were still impressive without noticeable glitching.
The plain ESP32 (no suffix) and ESP32-S3 are dual core with two identical main cores. I was not talking about some lower power core. Some other less well known kinds are also dual core but not supported by WLED. https://docs.espressif.com/projects/esp-techpedia/en/latest/chip-comparator-web/ESP32_Chip_Comparator_Portable.html
A useful way to test the HA/polling explanation would be to run the C3 again with the same preset, LED count and brightness, temporarily disable its HA integration and any other polling, and close the WLED browser UI while watching the effect. Then re-enable those clients one at a time. If the pauses track a particular client, that gives a much stronger clue than comparing two different boards alone. Keep the WLED version and output settings noted too: the C3-to-WROVER swap changes more than just the number of cores, so it does not by itself isolate the cause.
Hello … can you share what you are using for these 1024 LEDs? I have a string of lights I’ll use for holiday lights, but your display sounds awesome. Amazon.com: ALITOVE WS2811 12V LED Pixel Lights with xConnect RGB Addressable Bullet Pixels String Lights 100pcs IP68 Waterproof 12mm Diffused Programmable Color Chasing for Halloween Christmas Outdoor Decor : Home & Kitchen
Hi Scott. I started thinking to use LED strips, but decided on using LED panels which I now think may be fairly different - particularly because they are very compact for connecting and injecting power.
I don’t want to derail this thread, but I have been wondering about starting a new tread for my Xmas decoration project. I did have a look for other peoples projects, thoughts, suggestion on using panels of LEDs and was surprised to find none - so thought maybe the panels are just are too easy, just scaling up the old videos of connecting 3x3 of the older 8x8 LED panels.
BTW, My current configuration is a matrix of 4 strings of 4 panels of 16x16 LEDs. Thats using 4 GPIO pins and 4 power supplies, each driving 1024 LEDs. WLED handles it all so easily on my ESP32-S3-mini, and I haven’t had to inject extra power, though admittedly I have it set to brightness 32. I have not noticed any glitching or slow down. I have uploaded several seasonal GIFs with PixelForge. Only left to mount on my front door and start it running.
Edit: updated from 3x3 to 4x4 matrix.
I wrapped a separate ground wire around the DATA OUT wire from my ESP32-32U running to my 99 SK6812 NeoPixels that helped remove stray voltages and keep the data stream clean.
A dual-core board isn’t automatically required for 90 pixels, but it can help. On the C3 everything runs on one core, so WiFi, HA polling and the web UI can steal time from effect generation; on the dual-core ESP32/S3 the network stack can be scheduled on the other core, which often reduces timing jitter. But the swap also changes CPU speed, RAM and build, so erasmart35’s client-by-client test is the cleaner way to confirm. White flashes can also be data/power integrity, so don’t rule out grounding.
