Lights not responding to controller
My initial setup is Elite 4d-EXMU controller, BTF-LIGHTING RGB+Cool White SK6812 LED Strip 16.4FT 300LED DC12V IP68 and AXLHNITILED Driver 300Watts(100W X3)12V DC Low Voltage Output
I am using the latest 16.0.1 software and can connect no problem to the controller via wifi. I attached a screen shot of part of my config file.
My lights come on but they just stay on solid no matter what I do. Any help would be greatly appreciated.
Your settings look ok, I have 5v SK6812 LEDs with a gledopto ultra. Have you checked for a short on the data line.
Thanks for all the feed back. It ended up being a ground issue. I found out the hard way that you need to send a ground back to the controller when using a different power source. So I basically fried something in the controller. I wish that this information was provided in the instructions when I first bought the controller. However tech support was very good about getting back to me. So between them and the information online I was able to figure this out. I got another controller and wired it correctly and everything worked fine.
