Problem with stairs led
I need help solving flickering and signal corruption on an 18-step digital COB LED staircase installation.
Hardware & Setup
  • Steps: 18 steps total.
  • LED Strips: 24V Digital COB LED strips cut for each step (V+, GND, DATA).
  • Current Controller: Gledopto GL-C-015WL-D running WLED (5V DATA output).
  • Power Supply: Central 24V PSU in the main electrical distribution board.
  • Cabling: Bitner BiTprotect 6x0.5 mm² multi-core cable.
  • Distances: Distance between consecutive steps (DATA wire length) is 2–3 meters (6.5–10 ft).
Wiring Topology
  1. Power Supply: Both +24V and Power GND are wired individually to each step from the central panel in a Star topology.
  2. DATA Line: Pushed sequentially from Controller → Step 1 → Step 2 → ... → Step 18 in a Cascaded topology.
  3. Current Setup: Only the DATA wire runs from step to step (no local GND connected between adjacent steps). DATA runs in the same cable alongside 24V and GND power wires.
Symptoms & What I Tried
  • Step 1: Always works 100% reliably (The cable is shorter because it runs only from the controller)
  • Steps 2 to 18: Flickering, wrong colors, and data corruption increase progressively down the chain.
  • Resistor at Controller: An 82 Ω resistor at the main controller output alone did not solve the issue.
  • Mid-line Resistor: Placing a series resistor in the middle of the DATA line (between steps) noticeably improved signal stability.
Questions
  1. Would replacing the current controller with an Athom WLED controller improve signal delivery?
  2. How can I fix this signal degradation on 2–3m runs between steps?
  3. What is the main cause of data corruption in this topology and setup?
  4. Could using a different type of LED strip increase resistance to interference?
Thanks in advance for any advice!
Shield data wire between steps (2). Or use twisted-pair variant with ground wire.
This should reduce induced voltage or EMI in long wires (3).
Another option (though unnecessary IMO) is to add signal boosters or converters (V to A and back) between each step.
And no, controller is ok as your 1st step is working without flickering (1).
(5) Perhaps using 5V variant would reduce sensitivity but that’s not guaranteed.
I was able to eliminate flickering by taking a separate ground wire (besides the ground wire that you already have in the pixel circuit), connect it to the common ground coming out of your '32, twist it snuggly around the Data line (doesn’t have to be fancy or tight spiral but must touch data line) the length of the run from the '32 to your first pixel, making a common ground at that end also. I believe this works because the Data line is very suceptable to stray voltages.
