Subject: Possible daylight saving time / sunset calculation issue in Utah — WLED 0.16.0.1
I’m using WLED 0.16.0.1 on an ESP32 Ethernet Dig Quad controller in Woods Cross, Utah.
On November 1, 2026, after daylight saving time ended, my sunset-based lighting timers were activating approximately one hour later than expected.
My settings were:
- Time zone: US-MST/MDT
- UTC offset: 0 seconds
- Latitude: 40.87 N
- Longitude: 111.94 W
- NTP synchronization: Enabled
WLED displayed sunset at 18:24 (6:24 PM), approximately one hour later than the expected local sunset of 17:24 (5:24 PM).
I was able to work around the issue by adjusting my sunset timer offsets, but I would like to know whether this is a daylight saving time bug or an issue with my configuration.
Could you investigate whether sunset calculations are correctly accounting for the transition from MDT to MST?
Thank you!
