Setting up my M5Stamp C3U.
After getting everything installed and lights working I’m now running into the issue of using the correct GPIO ports. In the LED Preferences it allows the ability to select GPIO 1-5 and then 12-33. I’ve been able to get 3 and 4 working properly but none of the other pins. When I select pin 5 and save the settings the board disconnects which requires a power cycle and then looking back at the settings it reverted to the previous pin. So now I’m trying to dig around to figure out where I can select the correct pins in the config.
