Hi all
Short disclaimer: I know very little about what I’m doing
I tried to do my research but I realize that I am hitting walls left and right. It would be absolutely amazing if you could help me out!
Issue:
LED strip keeps flickering/flashing. Please see details of my setup below, here some of my troubleshooting steps.
Initially completely normal setup with strip plugged into V/GPIO16/G. Upon initial setup there was terrible flickering, even when limiting to 850A. Flickering was constant at high and medium brightness, at 13/255 brightness it still flashed every couple of seconds. Issue for both solid colors or effects
I then disabled the first LED and reduced the number of LEDs by one, which made the situation significantly better, especially for solid colors on high brightness. But there was still a lot of flickering/flashing every couple of seconds.
I then plugged the spare power and ground cables into the remaining V and G. No real change.
I then switched the data cable and WLED setting from GPIO 16 to GPIO 02. spare V and G are still plugged in as before. This has significantly improved the situation, even on full brightness white.
I then activated the first LED again and set the length back to 60 LEDs. Now some flickering is back. Around 233 bright warm white there is a pretty much constant flicker, at full brightness about once every 10 seconds.
What could be the issue here?
Wiring setup:
- 3m 12V BTF-Lighting FCOB WS2811 RGB IC LED Strip → 60 addressable zones
- 12V 10A power brick
- 5V-24V Ericsity ESP32 Controller
Data plugged into GPIO 02, power and ground plugged into neighbouring V and G.
Spare power and ground (I’m assuming these are for injection) are plugged into spare V and G.
There is currently no additional cables in use. Power brick to controller, controller directly into the LED strip with included cables. Controller to strip there is about 20cm of cables.
WLED Setup:
Power Situation:
LED strip:
- 3m strip with 21W/m = 63W
- 12V
- 5.25A
Power Brick:
- 12 V
- 5A
WLED:
- set to 4’800mA
