Thomas
1
Hello!
Wanted to change the segmentname of segment id 0 to XXX
WLED Version 0140-b4
curl -X POST “http://192.168.8.71/json/state” --data {“nn”:[{“0”:“XXX”}]} --header “Content-Type: application/json” --verbose
Does not work, got it from Chagpt
Maybe someone can help me. THX
ALDIY
2
I do not have access to Chagpt but this works in windows
send_wled_text.txt (109 Bytes)
Thomas
3
IT WORKS!
Thank you so much!!!
I’m trying to do the same thing via MQTT (using Home Assistant) but it doesn’t seem to work. Where am I wrong?
topic: wled/2de761/json
payload: {"seg":[{"id":0,"n":"07_10"}]}
who said wled/<mac>/json?
it is wled/<mac>/api
Todd
8
For anyone finding this that uses mac, the MacOS terminal command syntax is as follows:
curl http://192.168.1.163/json -d '{"seg":[{"id":0,"n":"Your text here"}]}' -H "Content-Type: application/json"
but replace the IP address with the IP of your target controller
