Long data line
When talking about long data lines, is it the length from the ESP32 data pin to the first LED in the run or the LAST LED in the run?
I’m using RS485 from one side of the house to the other but, to simplify installation, the distant end RS485 transceiver may be up to 10 feet from the LED strip. Will this distance be an issue with 18-3 wire (12v plus data) from the RS485 box to the LED strip?
The strips themselves are ~15 feet.
It is the distance to the first LED. Each one after that only sees a line equal to the length from it to the previous LED, usually a couple centimeters.
10ft isn’t far so probably it will just work. I do recommend using twisted pair wiring from the receiver to the LED and a separate (thicker) copper wire pair to your 12v power supply to further reduce the odds you run into problems.
Why twisted pair when only one is used? Would you ground the other to act as a pseudo shield?
For that matter, I could run 18-2 for power and 20-1 shielded for data.
You ground the 2nd line to ensure that the data connection references the same level as the ESP32 that transmit it. In general, a 10’ data line shouldn’t be an issue.
Sending data requires two wires, one for the outgoing current of the signal, the other for the returning current so you are using two wires. Putting the two wires together gives best signal integrity and reduces the odds of problems if wires cannot be kept short.
in my case, I have rs845 between the ESP32 and distant end.
Distant end RS485 is powered by a 12volt buck. 12v +/- are also sent along to power the LED which is giving the LED strip the same ground reference as the RS485rx chip.
So far, it’s working without a common ground reference between the two RS485 chips which I think is correct but I’m testing with short distances.
POE->ESP32 → RS485tx → 100ft run → RS485rx → 10ft run → LED Strip
Definitely little chance of error there, the RS485 Rx (probably a MAX485) chip is a good TTL driver.
The ground reference in this case is between the Rx board and the LED strip it’s driving. If you have a 12V->5v buck converter at the Rx end, you can effectively remove the 100’ ground wire if you wish. The ground from the BC to the Rx board becomes the common ground.
Once you’ve powered each Tx and Rx board with 5V, your “distant” data is handled by the requirements of the TxRx boards: a single pair of wires and proper termination on the boards.
Data transfer over the A/B wires is not the same as for typical ESP GPIO->LED setups (and that’s why it’s more reliable). In this kind of setup, I would definitely suggest RS485 boards with A/B line protection builtin (TVS diodes/serial fuses) to deal with possible ooops moments while wiring.
I agree with what @divsys says. My setup is similar but I am using 10W 12V RGB floodlight in my garden. I currently have just over 20 of them running from a single ESP32. Power is supplied from a 30A 12-15VDC supply on my patio and I have 10 and 12 AWG direct burial cables running to various points as you can see from the schematic.
My neighbor wanted some of my lights too so I ran the lights over RS485 and a 12 AWG power feed. I tried two modules for RS485 and found that the TTL to RS485 XY-017 boards worked well.
It was necessary to use one module for transmit and another for receive as all WS281x devices seems to continuously transmit thus making half-duplex (one module) operation impossible. This is running over a buried CAT6 cable (twisted pair wires are essential) as RS485 is balanced . balanced pair explained.
Previously I tried using a WLED single pixel (3-LEDs at 12V) buried under the lawn. This workred but was cumbersome and making sure that the buried boxes were 100% watertight was a pain and I hated digging up the grass every time something failed.
The RS485 converter boxes are now easily accessible and distance is no object within my garden. It can run up to 1,500m (4,000ft).
If you are using different power supplies at each end, I would reccomend that you use the 4 x remaining wires in the CAT6 cable to connect between ground points on the RS485 modules at each end. If, like me you have a single power suply then ground the powered ende leaving the wired unconnected ate the far light ends.
Here is a pic of a just finished and working WS2811 to RS485 subsystem. The cable runnung between the two RS485 boxes is a CAT6 cable. I am using one pair for transmit and another pair for receive. The remainig two pairs are joined together and grounded at the end closest to my power supply thus allowing static drain.
The trick with all this was to make sure that all the wiring junctons and all the electronics was inside completely waterproof containers. I spent quite a bit of time selecting appropriate boxes and jointing containers.
I hope this helps someone else.
I used RS 485 “bare metal” for my own ESP8266 board: https://wled.discourse.group/t/once-more-esp8266-based-wled-controller/11130 and WS2814 based Powerpixel https://wled.discourse.group/t/ws2814-based-power-led-pixel/9869
:wink:
