Hi all,
I have a 150 LED WS2811 5V strain.
I want to put the LEDs into a plate to display numbers.
Paint skills:
For that I created 10 segments (of the numbers) und 21 presets (the numbers).
Now I have to problems:
I have a button connectet to my esp8266 to cycle through the presets (numbers). But I don’t now how to programm this. The only thing I found in the documentation is the “FX=~” Macro, which is now only supportet in the preset configuration?! - I do not know how to do this. The preset should then set to be boot default.
Can some one explain me how to do this?
I conetcted this chain to a 5V 8A MEAN WELL power supply - on 3 points. On maximum brightness whithe color the power supply only uses about 15 watts from the wall. The brightness limiter is turned off. In my opinion the chain should suck more power? Do I need to connect the chain to even more points?
thanks
