OLED Display - TTGO LORA32
Try this bin file firmware.bin (1.2 MB)
Compiled with this usermod usermod.cpp.zip (2.4 KB)
Thats awesome thank you!! @srg74 :smiley:
I first tried the firmware.bin and that worked so I then loaded in the usermod file you prodided and that compiled and uploaded sucesfully! :smiley:
The screen flashes around every 5 seconds - is that normal?
Flickering is not normal. You have to play with U8g2 constructor. First try to remove reset pin. If not working here is library references https://github.com/olikraus/u8g2/wiki/u8x8setupcpp#ssd1306-128x64_noname
This is maybe yours - U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(U8X8_PIN_NONE, U8X8_PIN_SCL, U8X8_PIN_SDA);
@srg74 I’ve tried a few combinations now and the flash is either worst or the screen doesn’t turn on at all with the reset pin taken out the code. Its not a big problem, I’m just happy the screen works
@Henry thank you man
No worries @srg74 Thanks for all your help with this :slight_smile:
I’ve been playing with the code some more and still unable to fully stop the flashing.
I’ve been able to reduce it be increasing:
// How often we are redrawing screen
#define USER_LOOP_REFRESH_RATE_MS 20000
Looks like temporary solution too :slight_smile:
Hi @srg74 I’ve managed to get this working perfectly on an ESP8266 with an external OLED display.
Just a quick question. How easy would it be to change the code so the display always shows a line of text? For example my name.
Thanks!
Henry
I think not difficult.
