Hi! Is there a way to have the 0-255 brightness control fully usable when setting a max current? It appears the control value is capped at a certain value (so in my case roughly 100-255 is all the same brightness) rather than scaling down the entire 0-255 range so that 255 is my set max current.
That’s what the Automatic Brightness Level settings are supposed to be about.
For me, the actual solution to all those types of issues are simple: make sure you have proper power to run the LEDs you want. Trying to limit the LED output to the available power is typically counterproductive IMHO (YMMV).
