Typically RGBW means nondescript white, RGBWW means “Warm White”, RGBNW is “Normal White”, RGBCW is “Cold White”… unfortunately some sellers have since started to use RGBWW as 2 whites causing confusion, always need to dutifully check what you buy…
Does that mean there are pixel strips around with all of those combinations?
Can WLED support all of them, without any issue?
Well all the first 3 are the same, it’s just the color temp of the white chip that changes and wled doesn’t care about that beyond “there’s a 4th LED”.
The latter is usually referred to as RGBCCT and yes WLED supports some.
