Sunset vs sunrise
I want to use WLED with the “sunset” effect for my fish tank.
But if i select the effect it is a sunrise and also a sunset…Is there a way to just show the sunrise only…and a way to select sunset only… then i could use two effects at the beginning and ending of a day…
I also would like to know if there is a way to restart the sunrise effect. If i select it and switch to another and then go back to the first one i selected it continues where i left it. For the most effects this is no problem, but for sunrise it is.
thanks in advance…I am very enthusiastic about the WLED project.
rgds,
Joost
Did you ever get this sorted? I have the same idea and now I’m wondering if wled is not the best controller for a fish tank.
No, not even 1 response…You are the first :wink:
But…If you change the duration to a longer period it is only a sunset. The effect is NOT roling back.
So, i use HomeAssistant and create a autmation. When the sunset complets i will change the lights to daily white. And at night i slowly onvert to blue dimmed light also with an automation. So…almost what i wanted.
Thanks! I’ll look into trying to sort this out ASAP
ok, good luck, if you have a better idea or solution, let me know :wink:
