Created usermod APDS9960; compiles, there is no usermod listed on the WLED app usermod page.
Added the include for usermode APDS9960. Requesting help to see what I am missing.
#pragma once
#include "wled.h"
#include <Wire.h>
#include "Adafruit_APDS9960.h"
class USERMOD_APDS9960 : public Usermod {
private:
public:
void setup() {
Wire.begin();
apds.begin();
apds.enableProximity(true);
void loop() {
uint16_t proximity = apds.readProximity();
if (proximity > PROXIMITY_THRESHOLD) {
// Object is close to the sensor, set the LED brightness to maximum
bri = 255;
} else {
// Object is far from the sensor, reduce the LED brightness
bri = map(proximity, 0, PROXIMITY_THRESHOLD, 0, 255);
strip.setBrightness(bri);
strip.show();
#pragma once
#include "wled.h"
#include <Wire.h>
private:
public:
Adafruit_APDS9960 apds;
int PROXIMITY_THRESHOLD = 100;
//I²C SCL and SDA pins
#define HW_PIN_SCL 21
#define HW_PIN_SDA 22
//the pin that the interrupt is attached to
#define INT_PIN 3
void setup() {
Wire.begin(HW_PIN_SCL, HW_PIN_SDA);
apds.begin();
//set the interrupt threshold to fire when proximity reading goes above 175
apds.setProximityInterruptThreshold(0, 175);
//enable the proximity interrupt
apds.enableProximityInterrupt();
void loop() {
bri = 255;
} else {
strip.show();
void addToConfig(JsonObject& root)
JsonObject top = root.createNestedObject("APDS9960");
JsonArray pins = top.createNestedArray("pin");
pins.add(HW_PIN_SCL);
pins.add(HW_PIN_SDA);
Compiles; nothing shows up in WLED app, Usermods page.
This is my platformio_override.ini:
[env:esp32dev_usermod_APDS9960]
extends = env:esp32dev
build_flags = ${common.build_flags_esp32} -D WLED_RELEASE_NAME=ESP32 #-D WLED_DISABLE_BLYNK #-D WLED_DISABLE_BROWNOUT_DET
-D USERMOD_APDS9960
lib_deps = ${env.lib_deps}
adafruit/Adafruit BusIO@^1.14.1
# RECOMMENDED
# Accept new functionality in a backwards compatible manner and patches
adafruit/Adafruit APDS9960 Library @ ^1.2.3
# Accept only backwards compatible bug fixes
# (any version with the same major and minor versions, and an equal or greater patch version)
adafruit/Adafruit APDS9960 Library @ ~1.2.3
# The exact version
adafruit/Adafruit APDS9960 Library @ 1.2.3
Are you sure it is compiling/building the correct environment?
Add this line in your file above ‘#pragma once’ line:
#warning **** Included USERMOD_APDS9960 ****
#pragma once
#include "wled.h"
#include <Wire.h>
And check if you compile issues the warning, this way you’re sure it compiles correctly.
(as example here)
In file included from wled00/usermods_list.cpp:56:0:
wled00/../usermods/BME280_v2/usermod_bme280.h:2:2: warning: #warning **** Included USERMOD_BME280 version 2.0 **** [-Wcpp]
Ok, then you need to make sure platform IO compiles the right environment.
Click the Platform IO icon on the Bar → Project Tasks, you should see all available environments, expand yours (esp32dev_usermod_APDS9960) and click build.
Made some progress; was able to see the warning that was added, when compiling. Still no usermods in the WLed app. I have no esp32dev_usermod_APDS9960 environment; only esp32dev.
Only reference under Project tasks for usermod_APDS9960 is the Usermod folder has sub folder USERMOD_APDS9960 with usermod_apds9960.h in the sub folder.
You should create one. Preferably in platformio_override.ini.
Take existing [env:esp32dev] as an example and add desired build_flags. If you added include directives to usermod_list.cpp in the way other usermods are added there then it will compile your usermod as well (you will see a warning message if you added #pragma directive).
If the usermod is visible in WLED very much depends how usermod communicates with it. The description of that is in the example usermod.
Made the changes; is there something I can put in the apds9960.h file that will show on the WLED app, User Mod page? Warning displayed when compiled… Still nothing on User Mod page.
* addToConfig() can be used to add custom persistent settings to the cfg.json file in the "um" (usermod) object.
* It will be called by WLED when settings are actually saved (for example, LED settings are saved)
* If you want to force saving the current state, use serializeConfig() in your loop().
* CAUTION: serializeConfig() will initiate a filesystem write operation.
* It might cause the LEDs to stutter and will cause flash wear if called too often.
* Use it sparingly and always in the loop, never in network callbacks!
* addToConfig() will make your settings editable through the Usermod Settings page automatically.
* Usermod Settings Overview:
* - Numeric values are treated as floats in the browser.
* - If the numeric value entered into the browser contains a decimal point, it will be parsed as a C float
* before being returned to the Usermod. The float data type has only 6-7 decimal digits of precision, and
* doubles are not supported, numbers will be rounded to the nearest float value when being parsed.
* The range accepted by the input field is +/- 1.175494351e-38 to +/- 3.402823466e+38.
* - If the numeric value entered into the browser doesn't contain a decimal point, it will be parsed as a
* C int32_t (range: -2147483648 to 2147483647) before being returned to the usermod.
* Overflows or underflows are truncated to the max/min value for an int32_t, and again truncated to the type
* used in the Usermod when reading the value from ArduinoJson.
* - Pin values can be treated differently from an integer value by using the key name "pin"
* - "pin" can contain a single or array of integer values
* - On the Usermod Settings page there is simple checking for pin conflicts and warnings for special pins
* - Red color indicates a conflict. Yellow color indicates a pin with a warning (e.g. an input-only pin)
* - Tip: use int8_t to store the pin value in the Usermod, so a -1 value (pin not set) can be used
* See usermod_v2_auto_save.h for an example that saves Flash space by reusing ArduinoJson key name strings
* If you need a dedicated settings page with custom layout for your Usermod, that takes a lot more work.
* You will have to add the setting to the HTML, xml.cpp and set.cpp manually.
* See the WLED Soundreactive fork (code and wiki) for reference. https://github.com/atuline/WLED
* I highly recommend checking out the basics of ArduinoJson serialization and deserialization in order to use custom settings!
Please start listening and check other usermods and how they behave.
