Your power may be fine, but I’d do some extensive testing on the bench before I was certain - Make sure you can achieve your desired brightness on solid white and that it doesn’t dim or flicker as it gets farther down the strip
As for your data line, 10M is gonna cause you an issue at some point down the road. You’re definitely going to want to use level-shifters, and likely the 33Ω series termination resistor as well. You may want to consider using the max485 modules to convert the data signal to rs485, which is a 2-wire protocol that’s much less susceptible to induced noise and transmission line reflection. You would need 2 per data pin, one after the esp to convert, and one before the LEDs to convert back.
I am new at this so not sure that I am ready to offer advice, however, I have some experience with a similar setup. I am using about 13 meters of the WS2815 as well as a 150 watt power supply. In testing in my basement, I saw no visual degradation at 5 meters, but did see very minor drop at 10 meters. For my install I chose to connect the power at one point only, however, that was near midpoint (ie. about 6 or 7 meters running each way from the connection. I did use 18 AWG wire, however, my cable length is only 3 or 4 feet. I then connected my controller at the one end, where it sourced its power from the strip. I am seeing no problems.
I am assuming that your strips (like mine) are 30 pixels per meter.
Don’t know if this helps - just sharing.
Quarks - a correction in my previous info. I actually used only a 60 watt supply with there being just over 200 pixels at .3 watts per pixel. Confused it with the supply I got my son-in-law for a longer string where we made two mid string connections (about 1/4 of the length from each end - no pixel being more than a quarter length from a power source). His work great as well (using canned SP108E controllers).
