I have 2 different wled btf light strips hooked up to a controller. The first light strip I hook up is yellowish in color and the 2nd one is more orange-ish in color. When I switch them the 2nd one is always more orange. So I know it’s not the light strip…seems to be the order I put them in. I have this same issue with the exact same setup at 2 other spots in my building. Is the 2nd light strip not getting enough juice or why is the 2nd one always more orange in color? When I select certain color patters you can definitely tell the difference. Thank you for any help you can provide!
lower brightness to 20%, if it goes away, its you power setup that is lacking.
100% power issue. You can’t power that many LEDs from just the beginning. You need to add power injection.
Thank you for the comments. How do I add power injection or what should I use instead to power more lights? I’m currently using this. Is this only going to power one light strip sufficiently? Looking to hook up 2 to 4 light strips together. Thank you!
