A power relay for each segment?
Hello,
I am a new WLED user.
I have already gone through a lot of forum pages to find an answer to my question but I can’t find it.
In my installation, I use 6 LEDStrip (which are in different places in my room) on 6 different GPIO. WLED generates me a virtual band of my 6 LEDStrip. I made 6 segments to find my different lighting areas.
When I do an ON/OFF, the relay cuts or turns on the main power supply of my LEDStrip, normal operation…
I would like to have one relay per segment in order to cut the power of the LEDSTRIPs on the segments that are not used… it is useless for everything to be powered if I use only one LEDStrip.
I looked a little at the multi relay function, it will allow me to do something similar but it will not cleanly cut the signal.
Is it possible to assign a GPIO to a segment to switch a relay ?
Thank you in advance.
