There does seem to already be a post relating to this here, but it’s very confusing and seems to only include 50% of a conversation.
I hope that my suggestion makes it clear on what additions/changes I would like to be made to WLED. I have been able to do this already using espalexa, but it no longer seems to detect new devices whether I use a dot 1, 2 or app.
Basically, I would like to be able to define multiple names for the device and each one is linked to a specific effect so when you turn that device on it enables that mode. The initial setup would be something like this:
espalexa.addDevice("Gutter", colorCallback);
espalexa.addDevice("Rainbow Gutter", rainbowCallback);
espalexa.addDevice("Rainbow Cycle Gutter", rainbowCycleCallback);
espalexa.addDevice("Fire Gutter", fireCallback);
Then depending on whether it is a effect that allows colours or not, it may do this
void colorCallback(uint8_t brightness, uint32_t rgb) {
Serial.print("Loading color preset with brightness ");
Serial.print(brightness);
Serial.print(" and colour ");
Serial.println(rgb);
loadPreset(color_preset, brightness, rgb);
or this
void rainbowCallback(uint8_t brightness) {
Serial.print("Loading rainbow preset with brightness ");
Serial.println(brightness);
if (brightness == 0){
ws2812fx.stop();
} else {
ws2812fx.setMode(FX_MODE_RAINBOW);
ws2812fx.setSpeed(5000);
ws2812fx.setBrightness(brightness);
ws2812fx.start();
Obviously this hard-coded method wouldn’t work for this project, but it shouldn’t be a huge addition to implement. In the settings, it could just have a load of tickboxes - one for each effect and you can tick maybe 5 of them. Each one would automatically add a new espalexa device with the name of the effect added before or after the device name and whether it supports colour or not.
What do you think?
