I have set my longitude and latitude, I chose a preset for the lights to use and the times are correct for my location. I am in mountain time and that is also correct. I have saved. The lights still do go on and off. I am obviously missing something. Also I tried to create a playlist thinking that would do it with a preset and it did not work so when I deleted the playlist I created it deleted the preset too. How can I get that preset back. Thank you
can you post your timing setup
How does the WLED get the LOCAL time
Your preset is likely lost ![]()
For the future, you can save presets (and configurations) to avoid this problem.
As far as the night time On, morning Off issue - what does your Time&Macros section look like for “Time Controlled Presets”?
I use the Sunrise/Sunset entries all the time.
I have -18 minutes for Sunrise, so that my Off preset fires a little before the Sun comes up.
I use 18 minutes for Sunset so it gets a little darker before my night preset fires.
That works for me at Lat 49.04N although there is some variation between dead of winter and peak of summer light levels, YMMV.
I have at least 5 different devices using that setup and it’s quite stable
I noticed you’re referencing preset #71, do you actually have 71 presets?
I thought there was an upper limit on the max presets that you could use.
I know the ESP8266’s are fairly limited (32?) and while the ESP32 allows for more, I would wonder if that could be part of your issues.
Worst case, it might be worth saving out all your presets and then stripping down (temporarily) to just the 2 you need for your sunrise/sunset testing.
What version of WLED are you running and on what board?
I am using 13.3. I was advised by the smart lighting folks not to update. I confirmed I have well of 32 presents. They all work. Clarification , they all work on the timer.
Don’t know what to suggest other than strip it down to a very basic setup (after saving your presets and configs) and try to replicate with only 2 simple presets defined.
I haven’t had trouble with that in a very long time.
I’d be wary of a board that can’t be updated to the latest V0.14.
Why not upgrade? You could always put it back if necessary.
Thanks for all the help. It’s working. I had to download and start over but it is now working.
