Can I use it without Wi-Fi?
Is it possible to load lighting effects on the ESP8266 into internal memory and use them without an access point?
WLED has a number of effects builtin, they all will run independent of WiFi access.
You need WiFi to setup your configuration initially, but once that’s done you can set it to run automatically at power up or via buttons or time or all of the above…
Yes, you can control WLED device using IR remote or Wiz ESP-NOW remote.
Hello, can you help me with this, I’m new to this. Take videos and screenshots
How can I do it?
Both are covered in the KB.
Where exactly?
Search is your friend…
https://kno.wled.ge/interfaces/infrared/
Can I download effects to the microcontroller and store them there without using them later? WLED
Effects are built-into wled.
Are there other firmwares?
