Hello, I need advice on choosing a resource for my project.
I have two LED strips, each 5m long. There are 60 LEDs in one meter. I would like to create 10 tubes. Each tube would have 60 LEDs. 30 on one side and 30 on the other side. The LED strip is 5v.
I want to use wled 2d matrix. Mostly drip effect. https://www.youtube.com/shorts/eY-2DjejGaw According to the specifications, I would need a 40A power supply. But those tubes will never shine completely and fully white. What source should I use? 40A really doesn’t want to buy.
When using a strip of 10 meters long with 60 LEDs per meter, it needs a 34A source. But that will only be the value when all LEDs are lit white with maximum brightness. I assume that for the drip effect or other flashing effect a significantly weaker source will be enough. Maybe a 20A source would also be enough, but I don’t know. I could use a strip that only has 30 per meter, for 10 meters a 17A source would be enough. But with that strip the animation is not so nice anymore.
