Currently I have two wifi Tuya LED strip lines, 8m each, with flashed with Tasmota and integrated in Home Assistant.
Now i want to change my LED strips and install WLED. I have already installed thw WLED in two ESP8266 Dev Boards and i want now to buy the LED strips. Here i want your help:
What should i buy? I read that the WLED is working with WS2812B. Is that correct? Where i can buy? I found many stores sell W28XXX strips but all of them are offering 5m maximum - but i need 8m. What charger do i need?
So i need your help to install an 8m LED strip with the flashed ESP8266 Board.
WLED works fine with WS2812B . You choose the 30led / meter or 60 …etc .
Just buy two 4 meters strips and connect them together.
The power you need would depend on the final number of LEDs . The formula is there once you know the total LEDs .
And you can use only one controller to control the whole thing .
Hope this helps .
I have BTF-lighting which I see everywhere. It is mentioning on the label 9 Watts per 1 meter. Density is 30led / meter. Since this is 5v we say 9/5= 1.8 Amps . Hence 1.8/30 = 0.06 amp ( 60mA per led ) .
To calculate the maximum power requirement :
NumberOfLed x 60mA = Amps
30 x 60mA=1.8 A ( 5X1.8= Watts PSU )
100 x 60mA=6A ( 30 Watts PSU )
244x 60mA=14.6 A , 480 x 60mA=29 A … etc
You just need to know the risks with 5V 12A power supply . It is not a small thing and things could start to heat up or catch fire unless you are very careful specially if you go above 150 LED or the standard 5 m strips and use more amperes.
Due to risk, I use half of the recommended power rating and I am thinking now to move back to 12V strips to avoid the power complication ( I heard the new WS2815 are great but it’s expensive right now )
