hello,
i would like to make firmware for ESP8266EX, which is 160 mhz and has 16 mb rom. I would use the nightly build. I would like to know which microcontroller would be best to use and which tags should I change in step 1a.
microcontroller specifications:
Thank you very much for your help
Regards Andi
normal bin file does not run?
It works, but it reduces flash memory. And sometimes frequnecy.
make your own env, use larger partitions.
I would do this using WLED Online compiler
so I’m asking which microcontroller I can use to build it.
or which ones I need to define anew in step 1a
just use ESP8266, change to larger partitions.
Tnx.
I will give it a try
