Hi All,
I’m wondering if this led strip will work with WLED? and if so how would you wire it up.
I’ve got the 12v version and an ESP32 board which has a 12v input (and a converter for the ESP32 - which is a Wemos D1)… so all that’s sorted but no idea where to go from here.
I’ve read here, but not quite understanding it all White handling - WLED Project - I’m not even sure if these leds are PWM?
The diagram has 12v, CC, CW as the 3 inputs - and the 12v is easy - but the CC and CW are from the controller. How does this convert to usage in wled?
I’m planning to use this in the wardrobe - i’ve got the PIR stuff working fine, and its hooked into Home Assistant.
My plan is to use it like this
- Daytime - super bright, longer on time
- Evening - dimmed and shorter on-time
- Sleeping time - doesn’t come on, or really really dim and short timer
If i get it all working, happy to write up a guide for others to follow!
