unfortunately after only changing the white balance for PWM CCT no MQTT message will be send.
Is there a way to force sending MQTT a message through JSON API?
Background:
As Home Assistant rejects WLED Config with PWM CCT I created an Templated CCT Light.
I use MQTT messages as a trigger to reload the JSON status in HA.
This only works for changes for “on” and “bri”, but not for “cct”.
