Confirmed the setup in my pic works. If your data is on the right and not the left, just change the direction setting to Right. total 400 LEDs not 800 like you were trying.
Edit: My curtain does not have the lil chips on them though.
Jack is a spam bot. Ignore them and their links…
DId you have any luck here. I am in the exact same scenario.
I did this to and made a gap file disabling the last 20 leds on the strip in the matrix…
This works a litte, but somehow my image is flipped from the middle.
So if i put a line on the left side of the matrix it also apears on the right side… cant figure it out yet.
Will that was easier than i thougt. Disabled ZigZag in Xlights.
Here is te gap file.
Just make is 800 LED’s and than a Matrix.
"[","1","1","1","1","1","1","1","1","1","1","1","1","1","1","1","1","1","1","1","1",
"0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0",
"0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","]"
Maybe I should have posted here. However my divider results are slightly different then described here.
The pixels are in the right place out of the box. However my colors shift per (few) strands.
I’m working on a custom PCB to control a pixel curtain structured as a hub-and-spoke of 3-wire WS2812B pixels. The idea is to monitor and count the bits on the data signal using an MCU, and switch the signal to the segments in order using demultiplexers.
I’ve managed to parse the WS2812B data signal on an ATMega328P, so that I can output the switching signal during the LOW portion of the last bit of a particular segment, giving enough time to do the switching without compromising the data signal. It’s pure bit banging, so any AVR device running at 16MHz or above and with enough pins to address the segments should work.
[This approach would also support striping across the segments. Or the last segment could be used to chain any number of such modules together.]
My planned configuration is 24 segments (Xmas tree), using three 3:8 demuxes (74HCT238D) and 3 enable lines taking up 6 output pins. Physically, it is a ring shaped PCB with LED connectors around the circumference. I may make a chainable 7/8-segment module on the same principles for creating linear curtains.
So I had one of the curtains that by trial and error goes to 780 pixels. It goes a row then skips 40 pixels at the top before the start of the next row. I struggled with trying to get it working directly in wled but couldn’t figure it out. I mostly use xlights anyways so set it as a 1D string to 800 and then created a custom model in xlights which works perfectly.
Just wondering whether an ledmap file might do much of the same directly in WLED?
Not knocking your solution (xlights is hugely powerful), but a direct WLED solution might be useful too…
Just to add to this…
There seems to be 4 types of LED curtains we’ve identified in the wild: (“we” being the WLED MoonModules core team)
(And there’s possibly other variants as we haven’t seen any of the ones mentioned at the top of the thread with specifically numbered PCBs.)
#4 PCB detail:
Looking at #4 there’s 2 capacitors and 2 resistors. Data-in is connected directly to the strip that’s hanging down. This is curious because WS2812b only specify a 100nF decoupling capacitor per pixel, so I’m curious if the extra components in some way influence how long the strands are - is it possible to change the components and skip/split more or less pixels?
(I’ve also seen some on random Instagram reels that are around 60x60 curtains, so it would make sense that the chips are customizable in some way - but it was a very scammy advertisement so I don’t have info on the curtain they used in promo, which wasn’t what they were actually selling!)
There’s also some “prior art” here where someone was doing a similar thing several years back:
If anyone has some knowledge of the addressable pixel in the image above, I’d love to hear about it.
Yes, an LED map is the best way to solve this. Remap 780 pixels to 400.
Unfortunately you get the framerate for 780 pixels (around 42 FPS max) rather than the framerate for 400 pixels (around 84 FPS max) but you do benefit from less CPU overhead to calculate effects on 20x20 vs 20x40
Hi @Troy I have also got LED curtains with an “Controller-LED” in the T-Connector, see Support Smart LED Curtain · Issue #4569 · wled/WLED · GitHub . Are there currently any possibility to get it to work without hardware changes? It seems to need some impulse to address the next led column, see Support for LED Curtains, Active tee/hook for each vertical drop · Issue #790 · Makuna/NeoPixelBus · GitHub. Currently the first row works as expected and all other rows are lighting up very weird and blinking as long as data is transmitted.
You can tag me on GitHub as @troyhacks or find me on the two WLED Discord servers:
WLED MM 2D & Audio Dev (This is the one I’m most often using as it’s MoonModules-related)
I think you are out of luck with those weird ones that require a pulse. Really kinda sad that they broke the protocol to make those work.
I got 2 panels of the same type of curtains as you have pictured here and got them working with an LED map (which was fun to make since i have one panel reversed so i could have the power/data lines for both meet at the middle.) I have to wonder.. if you got some of those pebble light strands and just soldered on another 20 on the end of each fall of the curtain if one could dispense with the ledmap all together as there would no longer be any skipped numbers?
In theory, yes. (Sorry for the very late reply)
And if you had no need for freely hanging LEDs, you could loop the extra 20 back upwards, making 40-wide by 20-talk curtains.
Or even make double density strands that are freely hanging by offsetting the next 20 LEDs in between the first 20 - but that’s gonna need a somewhat complex map.
Could look cool tho!
I like the idea of these active pixel splitter boards - but it would be nice to have a generic part that just did the active splitting using regular LED WS281x stands or strips but could be adjusted with a jumper or something. Even 20/30/40 would be useful if an arbitrary number was too difficult.
To add to the very interesting info here, the Adafruit LED curtain ( NeoPixel LED Outdoor Netting - 100 x 20 LEDs - 1x5 Meter Sizing : ID 6166 : Adafruit Industries, Unique & fun DIY electronics and kits ) is of type 1: each vertical strip has a return wire and it picks up at the top of the next strip.
That ‘data output’ wire is just a separate wire run along the side. You still have to connect the main data line at the far end to it, in order to get the data back to the beginning end. This is ok for about 10ft or less runs. After that that data from the far end back to the beginning end will start to be degraded.
Seeds with that return data line have been available for several years now @ AliExpress. I have not seen them yet with the larger 20awg wire (I haven’t looked either) or the new 18awg wire seeds.
Rita Lights Is Ray Wu’s factory. So those in your pic are likely a quality item.
Thanks for your great summary!
What other lengths have you found and are there any indicators to predict how many a given listing will strip?
Edit: or if pre-addresed (type 2) LEDs are still a thing in ≥20×20 px/m²
