How can I set an effect to a segment in the payload using the rest_command in homeassistant?
Hi, I am a newbe… using homeassistant automation using the rest_command.wled_update to send a payload with a range of colors in different segments to WLED. That all works fine. Now I would want to add an effect (e.g. blink) to some segments. Iooked at the API documentation, however cannot find an example of how use which parameters and which function codes.
I tried things like the following, however that does not make a difference at all.
Does anyone have any suggestions?
“bri”: brightness,
“seg”: {
“bri”: 255,
“fx”: 2,
“i”: result.segments
