I have 1x esp32, 2x 24v 1000w power supplies and 2x ws2821b 10m strips
How can i use the esp to run both sets of lights, each one has its own power supply and the esp is powered by 1 of the power supplies with a buck converter to usb.
I tried connecting the grounds and it killed my esp32.
thanks in advance.
depending on how far that data line runs you may need a level shifter. You are already below data voltage spec and then you are splitting that to 2 strips, reducing it even more.
