You can use old build with Hue enabled but it is better to go for latest build or compile from source ( which i can personally confirms it works with hue v2 ) . Both options ( and more ) are here WLED installation (wled-install.github.io)
You are using sound reactive version ? if so then you are stuck as sound is no longer supported with esp8266 on version 14 . If audio is not involved then you have options
