Done a lot of reasearch and tried many different things but can get any resolution.
2 data lines come from SN74. One data line is about 1.5m, other ones is about 6m max.
Used a bunch of resistors (will add photos) and not getting any inprovment. Dont know where im going wrong if someome could please help with some ideas
Offering an alternate option, try one of these ultra tiny assembled controllers and mount it right at the start of the strip. They don’t need separate USB power, so real easy to hide away at the start of a run.
Okay thanks have gone and got a bunch of different R resistors in 0.5w but dont seem to be making any change. Have put a 1W resistor on and makes more of an improvement?
resistors can be small, power is not important but the value. 100 Ohms is a good staring point. also I just noticed you put the wrong shifter IC, it must be (A)HCT, you got a HC type which might be the source of your issues
I think i found my problem but i domt know how to solve it. So with running one data line its fine works perfext just slow on animations since so mamy pixels. But i was confused since half way there is a break in the data line to allow the new data line to come in but still controlling rest. Im wondering have i made a mistake with back up data wirimg for second data line?
