I’ve been following the Wiki to the T but I’m having issues with getting -D disables and overrides to work in the platform_override.ini file. I have successfully been able to set the data pin but I’m struggling to get the LED count to change.
Here’s my code I’m trying to get working
[platformio]
default_envs = esp32dev
[env:esp32dev]
board = esp32dev
platform = ${esp32.platform}
platform_packages = ${esp32.platform_packages}
build_flags = ${common.build_flags_esp32} -D WLED_RELEASE_NAME=ESP32 -D WLED_DISABLE_BLYNK #-D WLED_DISABLE_BROWNOUT_DET
-D LEDPIN=12
-D DEFAULT_LED_COUNT=96
lib_deps = ${esp32.lib_deps}
monitor_filters = esp32_exception_decoder
board_build.partitions = ${esp32.default_partitions}
Here’s the log
* Executing task in folder WLED-main: C:\Users\tech1\.platformio\penv\Scripts\platformio.exe run
Processing esp32dev (board: esp32dev; platform: espressif32@3.5.0; framework: arduino)
-----------------------------------------------------------------------------------------------------------------------------Library Manager: Installing SPI
Verbose mode can be enabled via `-v, --verbose` option
*** use existing my_config.h ***
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32dev.html
PLATFORM: Espressif 32 (3.5.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 0.0.0+sha.4b0c087
- tool-esptoolpy @ 1.30100.210531 (3.1.0)
- toolchain-xtensa32 @ 2.50200.97 (5.2.0)
Converting wled00.ino
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ strict
Found 35 compatible libraries
Scanning dependencies...
Dependency Graph
|-- FastLED @ 3.5.0
| |-- SPI @ 1.0
|-- IRremoteESP8266 @ 2.8.2
|-- ESPAsyncWebServerAircoookie @ 2.0.7+sha.b9349dc
| |-- AsyncTCP @ 1.2.0+sha.38b8475
| |-- FS @ 1.0
| |-- WiFi @ 1.0
| |-- LittleFS_esp32 @ 1.0.6+sha.f0817ca
| | |-- FS @ 1.0
| |-- FS @ 1.0
|-- NeoPixelBus @ 2.6.9
| |-- SPI @ 1.0
|-- Wire @ 1.0.1
|-- SD(esp32) @ 1.0.5
| |-- FS @ 1.0
| |-- SPI @ 1.0
|-- SD_MMC @ 1.0
| |-- FS @ 1.0
|-- SPI @ 1.0
|-- EEPROM @ 1.0.3
|-- ArduinoOTA @ 1.0
| |-- Update @ 1.0
| |-- WiFi @ 1.0
| |-- ESPmDNS @ 1.0
| | |-- WiFi @ 1.0
|-- DNSServer @ 1.1.0
| |-- WiFi @ 1.0
|-- ESPmDNS @ 1.0
| |-- WiFi @ 1.0
|-- WiFi @ 1.0
|-- ESP32 Async UDP @ 1.0.0
|-- WebServer @ 1.0
| |-- WiFi @ 1.0
| |-- FS @ 1.0
Building in release mode
Compiling .pio\build\esp32dev\lib02a\FastLED\FastLED.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\bitswap.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\colorpalettes.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\colorutils.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\hsv2rgb.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\lib8tion.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\noise.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\platforms.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\platforms\esp\32\clockless_rmt_esp32.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\power_mgt.cpp.o
Compiling .pio\build\esp32dev\lib02a\FastLED\wiring.cpp.o
Compiling .pio\build\esp32dev\src\FX.cpp.o
Compiling .pio\build\esp32dev\src\FX_2Dfcn.cpp.o
Compiling .pio\build\esp32dev\src\FX_fcn.cpp.o
Compiling .pio\build\esp32dev\src\alexa.cpp.o
Compiling .pio\build\esp32dev\src\blynk.cpp.o
Compiling .pio\build\esp32dev\src\bus_manager.cpp.o
.pio\libdeps\esp32dev\FastLED\src\platforms\esp\32\clockless_rmt_esp32.cpp: In static member function 'static void ESP32RMTController::init(gpio_num_t)':
.pio\libdeps\esp32dev\FastLED\src\platforms\esp\32\clockless_rmt_esp32.cpp:111:15: warning: variable 'espErr' set but not used [-Wunused-but-set-variable]
esp_err_t espErr = ESP_OK;
.pio\libdeps\esp32dev\FastLED\src\platforms\esp\32\clockless_rmt_esp32.cpp: In member function 'void ESP32RMTController::startOnChannel(int)':
.pio\libdeps\esp32dev\FastLED\src\platforms\esp\32\clockless_rmt_esp32.cpp:239:15: warning: variable 'espErr' set but not used [-Wunused-but-set-variable]
Compiling .pio\build\esp32dev\src\button.cpp.o
Compiling .pio\build\esp32dev\src\cfg.cpp.o
Compiling .pio\build\esp32dev\src\colors.cpp.o
Compiling .pio\build\esp32dev\src\dmx.cpp.o
Compiling .pio\build\esp32dev\src\e131.cpp.o
Compiling .pio\build\esp32dev\src\file.cpp.o
Compiling .pio\build\esp32dev\src\hue.cpp.o
Compiling .pio\build\esp32dev\src\improv.cpp.o
Compiling .pio\build\esp32dev\src\ir.cpp.o
Compiling .pio\build\esp32dev\src\json.cpp.o
wled00/FX_fcn.cpp: In member function 'void Segment::refreshLightCapabilities()':
wled00/FX_fcn.cpp:761:13: warning: unused variable 'type' [-Wunused-variable]
uint8_t type = bus->getType();
Compiling .pio\build\esp32dev\src\led.cpp.o
Compiling .pio\build\esp32dev\src\lx_parser.cpp.o
Compiling .pio\build\esp32dev\src\mqtt.cpp.o
Compiling .pio\build\esp32dev\src\net_debug.cpp.o
Compiling .pio\build\esp32dev\src\network.cpp.o
Compiling .pio\build\esp32dev\src\ntp.cpp.o
Compiling .pio\build\esp32dev\src\overlay.cpp.o
Compiling .pio\build\esp32dev\src\pin_manager.cpp.o
Compiling .pio\build\esp32dev\src\playlist.cpp.o
Compiling .pio\build\esp32dev\src\presets.cpp.o
Compiling .pio\build\esp32dev\src\set.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\ConnAckPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\PingRespPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\PubAckPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\PubCompPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\PubRecPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\PubRelPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\PublishPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\SubAckPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\async-mqtt-client\AsyncMqttClient\Packets\UnsubAckPacket.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\blynk\BlynkSimpleEsp.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\blynk\Blynk\BlynkDebug.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\blynk\Blynk\BlynkHandlers.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\blynk\Blynk\BlynkTimer.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\blynk\Blynk\utility.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\dmx\ESPDMX.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\dmx\SparkFunDMX.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\e131\ESPAsyncE131.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\espalexa\EspalexaDevice.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\network\Network.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\time\DS1307RTC.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\time\DateStrings.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\time\Time.cpp.o
Compiling .pio\build\esp32dev\src\src\dependencies\timezone\Timezone.cpp.o
Compiling .pio\build\esp32dev\src\udp.cpp.o
Compiling .pio\build\esp32dev\src\um_manager.cpp.o
Compiling .pio\build\esp32dev\src\usermod.cpp.o
Compiling .pio\build\esp32dev\src\usermods_list.cpp.o
Compiling .pio\build\esp32dev\src\util.cpp.o
Compiling .pio\build\esp32dev\src\wled.cpp.o
Compiling .pio\build\esp32dev\src\wled00.ino.cpp.o
Compiling .pio\build\esp32dev\src\wled_eeprom.cpp.o
Compiling .pio\build\esp32dev\src\wled_math.cpp.o
Compiling .pio\build\esp32dev\src\wled_serial.cpp.o
Compiling .pio\build\esp32dev\src\wled_server.cpp.o
Compiling .pio\build\esp32dev\src\ws.cpp.o
Compiling .pio\build\esp32dev\src\xml.cpp.o
Retrieved `.pio\build\esp32dev\partitions.bin' from cache
Compiling .pio\build\esp32dev\lib87e\SPI\SPI.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\IRac.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\IRrecv.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\IRsend.cpp.o
Archiving .pio\build\esp32dev\lib87e\libSPI.a
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\IRtext.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\IRtimer.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\IRutils.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Airton.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Airwell.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Aiwa.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Amcor.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Argo.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Arris.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Bose.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Carrier.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Coolix.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Corona.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Daikin.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Delonghi.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Denon.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Dish.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Doshisha.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Ecoclim.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Electra.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_EliteScreens.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Epson.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Fujitsu.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_GICable.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_GlobalCache.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Goodweather.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Gree.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Haier.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Hitachi.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Inax.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_JVC.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Kelon.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Kelvinator.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_LG.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Lasertag.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Lego.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Lutron.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_MWM.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Magiquest.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Metz.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Midea.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_MilesTag2.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Mirage.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Mitsubishi.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_MitsubishiHeavy.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Multibrackets.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_NEC.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Neoclima.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Nikai.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Panasonic.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Pioneer.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Pronto.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_RC5_RC6.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_RCMM.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Rhoss.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Samsung.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Sanyo.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Sharp.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Sherwood.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Sony.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Symphony.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Tcl.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Technibel.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Teco.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Teknopoint.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Toshiba.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Transcold.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Trotec.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Truma.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Vestel.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Voltas.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Whirlpool.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Whynter.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Xmp.cpp.o
Compiling .pio\build\esp32dev\lib251\IRremoteESP8266\ir_Zepeal.cpp.o
Compiling .pio\build\esp32dev\lib33b\AsyncTCP\AsyncTCP.cpp.o
Compiling .pio\build\esp32dev\lib47f\FS\FS.cpp.o
Compiling .pio\build\esp32dev\lib47f\FS\vfs_api.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\ETH.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev\lib3a2\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32dev\libb88\LittleFS_esp32\LITTLEFS.cpp.o
Compiling .pio\build\esp32dev\libb88\LittleFS_esp32\esp_littlefs.c.o
Archiving .pio\build\esp32dev\lib251\libIRremoteESP8266.a
Compiling .pio\build\esp32dev\libb88\LittleFS_esp32\lfs.c.o
Compiling .pio\build\esp32dev\libb88\LittleFS_esp32\lfs_util.c.o
Compiling .pio\build\esp32dev\libb88\LittleFS_esp32\littlefs_api.c.o
Archiving .pio\build\esp32dev\lib47f\libFS.a
Compiling .pio\build\esp32dev\libaa5\ESPAsyncWebServerAircoookie\AsyncEventSource.cpp.o
Compiling .pio\build\esp32dev\libaa5\ESPAsyncWebServerAircoookie\AsyncWebSocket.cpp.o
Compiling .pio\build\esp32dev\libaa5\ESPAsyncWebServerAircoookie\SPIFFSEditor.cpp.o
Archiving .pio\build\esp32dev\lib33b\libAsyncTCP.a
Compiling .pio\build\esp32dev\libaa5\ESPAsyncWebServerAircoookie\WebAuthentication.cpp.o
Compiling .pio\build\esp32dev\libaa5\ESPAsyncWebServerAircoookie\WebHandlers.cpp.o
Compiling .pio\build\esp32dev\libaa5\ESPAsyncWebServerAircoookie\WebRequest.cpp.o
Compiling .pio\build\esp32dev\libaa5\ESPAsyncWebServerAircoookie\WebResponses.cpp.o
Compiling .pio\build\esp32dev\libaa5\ESPAsyncWebServerAircoookie\WebServer.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\Esp32_i2s.c.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\HsbColor.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\HslColor.cpp.o
Archiving .pio\build\esp32dev\lib3a2\libWiFi.a
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\HtmlColor.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\HtmlColorNameStrings.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\HtmlColorNames.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\HtmlColorShortNames.cpp.o
Archiving .pio\build\esp32dev\libb88\libLittleFS_esp32.a
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\NeoEsp32RmtMethod.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\NeoEsp8266DmaMethod.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\NeoEsp8266UartMethod.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\NeoEspBitBangMethod.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\NeoGamma.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\NeoPixelAnimator.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\NeoPixelAvr.c.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\Rgb48Color.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\RgbColor.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\RgbColorBase.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\Rgbw64Color.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\RgbwColor.cpp.o
Compiling .pio\build\esp32dev\lib130\NeoPixelBus\internal\SegmentDigit.cpp.o
Compiling .pio\build\esp32dev\lib818\Wire\Wire.cpp.o
Compiling .pio\build\esp32dev\lib183\SD\SD.cpp.o
Compiling .pio\build\esp32dev\lib183\SD\sd_diskio.cpp.o
Compiling .pio\build\esp32dev\lib183\SD\sd_diskio_crc.c.o
Compiling .pio\build\esp32dev\lib15e\SD_MMC\SD_MMC.cpp.o
Compiling .pio\build\esp32dev\libf9b\EEPROM\EEPROM.cpp.o
Compiling .pio\build\esp32dev\lib6a0\Update\HttpsOTAUpdate.cpp.o
Compiling .pio\build\esp32dev\lib6a0\Update\Updater.cpp.o
Archiving .pio\build\esp32dev\libaa5\libESPAsyncWebServerAircoookie.a
Compiling .pio\build\esp32dev\libf31\ESPmDNS\ESPmDNS.cpp.o
Compiling .pio\build\esp32dev\libcab\ArduinoOTA\ArduinoOTA.cpp.o
Compiling .pio\build\esp32dev\lib090\DNSServer\DNSServer.cpp.o
Compiling .pio\build\esp32dev\lib9f5\AsyncUDP\AsyncUDP.cpp.o
Compiling .pio\build\esp32dev\lib31c\WebServer\Parsing.cpp.o
Compiling .pio\build\esp32dev\lib31c\WebServer\WebServer.cpp.o
Archiving .pio\build\esp32dev\lib15e\libSD_MMC.a
Archiving .pio\build\esp32dev\lib183\libSD.a
Archiving .pio\build\esp32dev\lib818\libWire.a
Archiving .pio\build\esp32dev\lib130\libNeoPixelBus.a
Compiling .pio\build\esp32dev\lib31c\WebServer\detail\mimetable.cpp.o
Retrieved `.pio\build\esp32dev\libFrameworkArduinoVariant.a' from cache
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Archiving .pio\build\esp32dev\lib6a0\libUpdate.a
Archiving .pio\build\esp32dev\libf9b\libEEPROM.a
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WMath.cpp.o
Archiving .pio\build\esp32dev\libf31\libESPmDNS.a
Compiling .pio\build\esp32dev\FrameworkArduino\WString.cpp.o
Archiving .pio\build\esp32dev\lib090\libDNSServer.a
Compiling .pio\build\esp32dev\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-adc.c.o
Archiving .pio\build\esp32dev\libcab\libArduinoOTA.a
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-ledc.c.o
Archiving .pio\build\esp32dev\lib9f5\libAsyncUDP.a
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-log.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cencode.c.o
C:\Users\tech1\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c: In function 'spiTransferBytesNL':
C:\Users\tech1\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:922:39: warning: initialization
from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_out8 = &result[c_longs-1];
C:\Users\tech1\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:923:40: warning: initialization
uint8_t * last_data8 = &last_data;
Compiling .pio\build\esp32dev\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_pulse.c.o
Archiving .pio\build\esp32dev\lib31c\libWebServer.a
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32dev\libFrameworkArduino.a
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [== ] 22.1% (used 72332 bytes from 327680 bytes)
Flash: [======== ] 78.5% (used 1235361 bytes from 1572864 bytes)
Building .pio\build\esp32dev\firmware.bin
esptool.py v3.1
Merged 1 ELF section
bin_rename_copy([".pio\build\esp32dev\firmware.bin"], [".pio\build\esp32dev\firmware.elf"])
bin_gzip([".pio\build\esp32dev\firmware.bin"], [".pio\build\esp32dev\firmware.elf"])
=============================================== [SUCCESS] Took 42.63 seconds ===============================================
Environment Status Duration
esp32dev SUCCESS 00:00:42.627
================================================ 1 succeeded in 00:00:42.627 ================================================ * Terminal will be reused by tasks, press any key to close it.
The parts that stick out in yellow are these
