I’m hoping someone is using the same board and has been able to compile with the platformio_override.ini file in place. I can compile in VS no problem when I remove/rename the platformio_override.ini file. So I know the issue is in there. I followed the instructions on the site Compiling WLED - WLED Project Making a custom environment. I have removed all my -D lines and have reset platformio by removing the .platformio/env directory. Still the same error "The terminal process “C:\Users\CE.platformio\penv\Scripts\platformio.exe ‘run’, ‘–verbose’” terminated with exit code: 1. " platformio ‘run’ --verbose gives no additional information
WLED version downloaded 8/9/2022 version 0.13.1
Git 2.34.1.windows.1
Note I changed all https to httpss to post. I couldn’t nab enough points until I posted?
Example PlatformIO Project Configuration Override
Copy to platformio_override.ini to activate overrides
Please visit documentation: Redirecting...
[platformio]
default_envs = esp32dev
[env:esp32dev]
board = esp32dev
platform = ${esp32.platform}
platform_packages = ${esp32.platform_packages}
build_flags = ${common.build_flags_esp32} -D WLED_RELEASE_NAME=ESP32 #-D WLED_DISABLE_BLYNK #-D WLED_DISABLE_BROWNOUT_DET
lib_deps = ${esp32.lib_deps}
monitor_filters = esp32_exception_decoder
board_build.partitions = ${esp32.default_partitions}
; *** Use custom settings from file my_config.h
-DWLED_USE_MY_CONFIG
; *** To use the below defines/overrides, copy and paste each onto it’s own line just below build_flags in the section above.
; disable specific features
; -D WLED_DISABLE_OTA
; -D WLED_DISABLE_ALEXA
; -D WLED_DISABLE_BLYNK
; -D WLED_DISABLE_HUESYNC
; -D WLED_DISABLE_INFRARED
; -D WLED_DISABLE_WEBSOCKETS
; PIN defines - uncomment and change, if needed:
; -D LEDPIN=2
; -D BTNPIN=0
; -D TOUCHPIN=T0
; -D IRPIN=4
; -D RLYPIN=12
; -D RLYMDE=1
; digital LED strip types - uncomment only one ! - this will disable WS281x / SK681x support
; -D USE_APA102
; -D USE_WS2801
; -D USE_LPD8806
; PIN defines for 2 wire LEDs
; -D CLKPIN=0
; -D DATAPIN=2
; to drive analog LED strips (aka 5050) hardware configuration is no longer necessary
; configure the settings in the UI as follows (hard):
; for the Magic Home LED Controller use PWM pins 5,12,13,15
; for the H801 controller use PINs 15,13,12,14 (W2 = 04)
; for the BW-LT11 controller use PINs 12,4,14,5
; set the name of the module - make sure there is a quote-backslash-quote before the name and a backslash-quote-quote after the name
; -D SERVERNAME=“"WLED"”
; set the number of LEDs
; -D DEFAULT_LED_COUNT=30
; set milliampere limit when using ESP pin to power leds
; -D ABL_MILLIAMPS_DEFAULT=850
; enable IR by setting remote type
; -D IRTYPE=0 ;0 Remote disabled | 1 24-key RGB | 2 24-key with CT | 3 40-key blue | 4 40-key RGB | 5 21-key RGB | 6 6-key black | 7 9-key red | 8 JSON remote
; set default color order of your led strip
; -D DEFAULT_LED_COLOR_ORDER=COL_ORDER_GRB
log
- Executing task: C:\Users\CE.platformio\penv\Scripts\platformio.exe run --verbose
Processing esp32dev (board: esp32dev; platform: espressif32@3.5.0; platform_packages: framework-arduinoespressif32 @ httpss://github.com/Aircoookie/arduino-esp32.git#1.0.6.4; build_unflags: ; build_flags: -DMQTT_MAX_PACKET_SIZE=1024, -DSECURE_CLIENT=SECURE_CLIENT_BEARSSL, -DBEARSSL_SSL_BASIC, -D CORE_DEBUG_LEVEL=0, -D NDEBUG, -D IR_ENABLE_DEFAULT=false, -D DECODE_HASH=true, -D DECODE_NEC=true, -D DECODE_SONY=true, -D DECODE_SAMSUNG=true, -D DECODE_LG=true, -DWLED_USE_MY_CONFIG -g, -DARDUINO_ARCH_ESP32, -D CONFIG_ASYNC_TCP_USE_WDT=0, -D LOROL_LITTLEFS -D WLED_RELEASE_NAME=ESP32; lib_deps: fastled/FastLED @ 3.5.0, IRremoteESP8266 @ 2.8.2, httpss://github.com/Aircoookie/ESPAsyncWebServer.git @ ~2.0.4, httpss://github.com/lorol/LITTLEFS.git, makuna/NeoPixelBus @ 2.6.9, httpss://github.com/pbolduc/AsyncTCP.git @ 1.2.0; monitor_filters: esp32_exception_decoder; board_build.partitions: tools/WLED_ESP32_4MB_1MB_FS.csv
-DWLED_USE_MY_CONFIG; framework: arduino; board_build.flash_mode: dout; monitor_speed: 115200; upload_speed: 115200; lib_compat_mode: strict; extra_scripts: pre:pio-scripts/set_version.py, post:pio-scripts/output_bins.py, post:pio-scripts/strip-floats.py, pre:pio-scripts/user_config_copy.py)
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------*** use existing my_config.h ***
CONFIGURATION: httpss://docs.platformio.org/page/boards/espressif32/esp32dev.html
PLATFORM: Espressif 32 (3.5.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 0.0.0+sha.4b0c087 (git+httpss://github.com/Aircoookie/arduino-esp32.git#1.0.6.4)
- tool-esptoolpy @ 1.30100.210531 (3.1.0)
- toolchain-xtensa32 @ 2.50200.97 (5.2.0)
xtensa-esp32-elf-g++ -o “C:\Users\CE\Wled\WLED-main\wled00\wled00.ino.cpp” -x c++ -fpreprocessed -dD -E “C:\Users\CE\AppData\Local\Temp\tmpz8wruj0n”
LDF: Library Dependency Finder → httpss://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ strict
Found 35 compatible libraries
Scanning dependencies…
Warning: IgnoredESPAsyncTCPdependency forESP Async WebServerlibrary
Dependency Graph
|-- FastLED @ 3.5.0 (License: MIT, Path: C:\Users\CE\Wled\WLED-main.pio\libdeps\esp32dev\FastLED)
| |-- SPI @ 1.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\SPI)
|-- IRremoteESP8266 @ 2.8.2 (License: Unknown, Path: C:\Users\CE\Wled\WLED-main.pio\libdeps\esp32dev\IRremoteESP8266)
|-- ESP Async WebServer @ 2.0.5+sha.580743f (License: LGPL-3.0, URI: git+httpss://github.com/Aircoookie/ESPAsyncWebServer.git, Path: C:\Users\CE\Wled\WLED-main.pio\libdeps\esp32dev\ESP Async WebServer)
| |-- AsyncTCP @ 1.2.0+sha.38b8475 (License: LGPL-3.0, URI: git+httpss://github.com/pbolduc/AsyncTCP.git, Path: C:\Users\CE\Wled\WLED-main.pio\libdeps\esp32dev\AsyncTCP)
| |-- FS @ 1.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\FS)
| |-- WiFi @ 1.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\WiFi)
| |-- LittleFS_esp32 @ 1.0.6+sha.f0817ca (License: LGPL-2.0, URI: git+https://github.com/lorol/LITTLEFS.git, Path: C:\Users\CE\Wled\WLED-main.pio\libdeps\esp32dev\LittleFS_esp32)
|-- NeoPixelBus @ 2.6.9 (License: Unknown, Path: C:\Users\CE\Wled\WLED-main.pio\libdeps\esp32dev\NeoPixelBus)
|-- AsyncTCP @ 1.2.0+sha.38b8475 (License: LGPL-3.0, URI: git+https://github.com/pbolduc/AsyncTCP.git, Path: C:\Users\CE\Wled\WLED-main.pio\libdeps\esp32dev\AsyncTCP)
|-- Wire @ 1.0.1 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\Wire)
|-- EEPROM @ 1.0.3 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\EEPROM)
|-- ArduinoOTA @ 1.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\ArduinoOTA)
| |-- Update @ 1.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\Update)
| |-- ESPmDNS @ 1.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\ESPmDNS)
|-- DNSServer @ 1.1.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\DNSServer)
|-- ESP32 Async UDP @ 1.0.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\AsyncUDP)
|-- WebServer @ 1.0 (License: Unknown, Path: C:\Users\CE.platformio\packages\framework-arduinoespressif32\libraries\WebServer)
Building in release mode
Using tempfile C:\Users\CE\Wled\WLED-main.pio\build\esp32dev\tmpnyx1knef.tmp for command line:
xtensa-esp32-elf-g++ -o .pio/build/esp32dev/src/wled00.ino.cpp.o -c -fno-rtti -fno-exceptions -std=gnu++11 -g -Os -g3 -Wall -nostdlib -Wpointer-arith -Wno-error=unused-but-set-variable -Wno-error=unused-variable -mlongcalls -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -Wno-error=deprecated-declarations -Wno-error=unused-function -Wno-unused-parameter -Wno-sign-compare -fstack-protector -fexceptions -Werror=reorder -DPLATFORMIO=60103 -DARDUINO_ESP32_DEV -DMQTT_MAX_PACKET_SIZE=1024 -DSECURE_CLIENT=SECURE_CLIENT_BEARSSL -DBEARSSL_SSL_BASIC -DCORE_DEBUG_LEVEL=0 -DNDEBUG -D_IR_ENABLE_DEFAULT_=false -DDECODE_HASH=true -DDECODE_NEC=true -DDECODE_SONY=true -DDECODE_SAMSUNG=true -DDECODE_LG=true -DWLED_USE_MY_CONFIG -DARDUINO_ARCH_ESP32 -DCONFIG_ASYNC_TCP_USE_WDT=0 -DLOROL_LITTLEFS -DWLED_RELEASE_NAME=ESP32 -DWLED_VERSION=0.13.2-a0 -DESP32 -DESP_PLATFORM -DF_CPU=240000000L -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbe*** [.pio\build\esp32dev\partitions.bin] Sourcetools\WLED_ESP32_4MB_1MB_FS.csv dtl-DWLED_USE_MY_CONFIG' not found, needed by target.pio\build\esp32dev\partitions.bin’.
s/esp_config.h" -DARDUINO=10805 -DARDUINO_ARCH_ESP32 -DARDUINO_VARIANT="esp32" “-DARDUINO_BOARD="Espressif ESP32 Dev Module"” -Iinclude -Iwled00 -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/WebServer/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/AsyncUDP/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/DNSServer/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/ArduinoOTA/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/ESPmDNS/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/Update/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/Wire/src -I.pio/libdeps/esp32dev/NeoPixelBus/src “-I.pio/libdeps/esp32dev/ESP Async WebServer/src” -I.pio/libdeps/esp32dev/LittleFS_esp32/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/FS/src -I.pio/libdeps/esp32dev/AsyncTCP/src -I.pio/libdeps/esp32dev/IRremoteESP8266/src -I.pio/libdeps/esp32dev/FastLED/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/libraries/SPI/src -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/config -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_trace -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/app_update -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/asio -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bootloader_support -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/bt -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/coap -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/console -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/driver -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/efuse -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp-tls -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32 -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_adc_cal -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_event -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_client -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_http_server -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_ota -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_https_server -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_ringbuf -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp_websocket_client -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/espcoredump -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ethernet -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/expat -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fatfs -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freemodbus -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/freertos -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/heap -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/idf_test -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/jsmn -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/json -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/libsodium -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/log -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/lwip -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mbedtls -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mdns -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/micro-ecc -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/mqtt -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/newlib -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nghttp -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/nvs_flash -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/openssl -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protobuf-c -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/protocomm -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/pthread -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/sdmmc -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/smartconfig_ack -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/soc -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spi_flash -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/spiffs -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcp_transport -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/tcpip_adapter -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/ulp -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/unity -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/vfs -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wear_levelling -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wifi_provisioning -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/wpa_supplicant -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/xtensa-debug-module -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/esp32-camera -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/tools/sdk/include/fb_gfx -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/cores/esp32 -IC:/Users/CE/.platformio/packages/framework-arduinoespressif32/variants/esp32 wled00/wled00.ino.cpp
xtensa-esp32-elf-g++ @C:\Users\CE\Wled\WLED-main.pio\build\esp32dev\tmpnyx1knef.tmp
=========================================================================================================================================== [FAILED] Took 6.91 seconds ===========================================================================================================================================
Environment Status Duration
nodemcuv2 IGNORED
esp8266_2m IGNORED
esp01_1m_full IGNORED
esp07 IGNORED
d1_mini IGNORED
heltec_wifi_kit_8 IGNORED
h803wf IGNORED
esp32dev FAILED 00:00:06.913
esp32_eth IGNORED
esp32s2_saola IGNORED
esp32c3 IGNORED
esp8285_4CH_MagicHome IGNORED
esp8285_H801 IGNORED
d1_mini_5CH_Shojo_PCB IGNORED
d1_mini_debug IGNORED
d1_mini_ota IGNORED
anavi_miracle_controller IGNORED
wemos_shield_esp32 IGNORED
m5atom IGNORED
sp501e IGNORED
sp511e IGNORED
athom7w IGNORED
athom15w IGNORED
MY9291 IGNORED
travis_esp8266 IGNORED
travis_esp32 IGNORED
codm-controller-0.6 IGNORED
codm-controller-0.6-rev2 IGNORED
elekstube_ips IGNORED
====================================================================================================================================== 1 failed, 0 succeeded in 00:00:06.913 ======================================================================================================================================
- The terminal process “C:\Users\CE.platformio\penv\Scripts\platformio.exe ‘run’, ‘–verbose’” terminated with exit code: 1.
- Terminal will be reused by tasks, press any key to close it.
