I download a copy of Wled 0.14.0 a few hours after release, I opened up vsc/platformio and compiled all my ESP8266 firmware with the following options:
# my config
[env:custom_esp_d1_mini_board]
extends = env:d1_mini
build_flags = ${env:d1_mini.build_flags} -D WLED_DISABLE_ESPNOW -D USERMOD_DALLASTEMPERATURE -D USERMOD_FOUR_LINE_DISPLAY
${env:d1_mini.lib_deps}
OneWire@~2.3.5
olikraus/U8g2 @ ^2.28.8
[env:custom_build_mini_no_espnow]
[env:custom_build_Multirelay]
build_flags = ${env:d1_mini.build_flags} -D USERMOD_MULTI_RELAY
All compiled fine and I updated the modules one by one with out errors. All modules work great so far, and I have copy’s of the bins.
Today vsc/platformio will not compile that same set of options, just throws errors.
However if I add
-D PIO_FRAMEWORK_ARDUINO_MMU_CACHE16_IRAM48`
as suggested by blazoncek in this thread Help with multi_relay needed - #11 by blazoncek
It compiles fine. However the binary is flawed. I can connect to the Wled AP and set my wifi.
But after reboot I cant connect to the module. it seems to be on my wifi, the web page attempts to load but does not.
I’m glad I was able to at least get one good compile out of vsc/platformio and save the bin’s.
What up with VSC/platformio? it seems schizophrenic ![]()
