I just got my QuinLED-Dig-Uno (ESP32 version) board (still awaiting the LED strip to come in the mail) and successfully flashed the latest WLED (0.11.0) version ((WLED_0.11.0_ESP32_ledpin16.bin) on it; I was able to configure my network setup and connect with the app on my mobile phone.
Next, I installed VSCode and PlatformIO, compiled WLED and flashed my board. The issue I have is that with my own complied code - the app times out accessing the ESP32 board; While WLED-AP works as expected and my network credentials are entered - the ESP32 WiFi never connects to my WiFi network (checked all clients on my network). Flashing back the pre-compiled binary gets everything to work as before;
This is the ENV I used in platformio.ini -
[env:wemos_d1_mini32]
platform = espressif32
board = wemos_d1_mini32
build_unflags = {common.build_unflags}
build_flags = {common.build_flags_esp32} -D LEDPIN=16
lib_ignore =
ESPAsyncTCP
ESPAsyncUD
I think that my env configuration is incorrect but not sure what it should be set to (I tied dozens of flags/options without success).
Any help is greatly appreciated !
              I believe it has to do with the load address needing established not at 0x0000… but 0x1000…
              Thank you for your quick reply.
Could you please point me to a link/site that shows how to do this?
Much appreciated!
              Thanks for the link - very helpful.
ESP32 board is detected and the code is loaded into 0x1000  as follows:
Detecting chip type… ESP32
Connecting…
Chip Info:
- Chip Model: ESP32D0WDQ6 (revision 1)*
- Max CPU Frequency: 240MHz*
- Has Factory-Calibrated ADC: YES*
- MAC Address: 7C:9E:BD:39:7A:C0*
 Uploading stub…
 Running stub…
 Stub running…
 Changing baud rate to 460800
 Changed.
- Flash Frequency: 40MHz*
 Erasing flash (this may take a while)…
 Chip erase completed successfully in 2.4s
 Compressed 15872 bytes to 10320…
 Writing at 0x00001000… (100 %)Wrote 15872 bytes (10320 compressed) at 0x00001000 in 0.3 seconds (effective 501.6 kbit/s)…
 Hash of data verified.
Unfortunately, I get the same issue -
On my owned compiled bin - I can get into WLED-AP, configure the SSID and enter credentials - and yet - the device does not connect to my WiFi network (the same way it does with the pre-compiled binary).
Any suggestion on how to further debug this is highly appreciated.
              I think you also need these:
[esp32]
build_flags = -w -g
-DARDUINO_ARCH_ESP32
-DCONFIG_LITTLEFS_FOR_IDF_3_2
              Thanks huggy-d1.
These are already present in my setup.
Do you happen to know how was WLED_0.11.0_ESP32_ledpin16.bin created (which [env:?] was used)?
Was it used based on an existing platformio.ini env? or, a custom env (manually created like the one I copied above)?
Thanks!
              I would have to either ask @Aircookie, or figure out what tools are used to build / publish the firmware.  I’d like to think I could figure it out, but don’t have the time.
              I truly appreciate your help on this so far!
I will follow your suggestion.
Many thanks!
