Hello,
I have a WS2815 5m led strip connected to a nodemcu. I started using node-red to send json data so I can have custom animation. One of these is using 3 segments and 2 different animation. The JSON is as follow:
msg.payload =
"on":true,
"bri":255,
"transition":5,
"ps":-1,
"pss":0,
"pl":-1,
"mainseg":0,
"seg":
"id":0,
"desc":"Left",
"start":0,
"stop":100,
"grp":1,
"spc":0,
"on":true,
"bri":255,
"col":
[255,0,0],
[0,0,0],
[255,255,255]
"fx":76,
"sx":93,
"ix":142,
"pal":0,
"sel":true,
"rev":true,
"mi":false
"id":1,
"desc":"Top",
"start":100,
"stop":200,
"grp":1,
"spc":0,
"on":true,
"bri":255,
"col":
[255,0,0],
[0,0,255],
[0,0,0]
"fx":108,
"sx":150,
"ix":151,
"pal":0,
"sel":true,
"rev":true,
"mi":true
"id":2,
"desc":"Right",
"start":200,
"stop":300,
"grp":1,
"spc":0,
"on":true,
"bri":255,
"col":
[255,0,0],
[0,0,0],
[255,255,255]
"fx":76,
"sx":93,
"ix":142,
"pal":0,
"sel":true,
"rev":false,
"mi":false
Now, when I send the data, it does like I want, left and right does a sort of falling down segment and the top segment does another animation. But after a random amount of seconds (under 10), the top segment will change animation and follow left and right (like if left and right segment where now 1-150 and 150-300). I’ve checked in the ui and all segment are correctly configured. It seems something in the loop doesn’t work properly.
edit: here’s a video to show what I’m talking about
https://youtu.be/_ZUHkXSLwas
newedit: I found out that it revert to the mainseq fx (but retain color). I don’t want that and I haven’t found how to not use that
Thank you
