I have a successfully flashed and soldered my D1 mini. I originally hooked the D1 mini to LED strings. When the WLED application is set to solid red, green or blue the strings follow the color like they should. I also have a set of LED strings that I purchased at the same time. The strings are not working as the strips behave. When I go solid blue the lights properly go blue. The issue is that when I select the color red in the WLED app the led bulbs in the string light glow green, If I make WLED turn the lights green the lights glow red. The color red and green are inverted on the strings only. I have gone back to strips and the strips behave properly.
I re-flashed my D1 mini which fixed another issue I was having but the strings do not following WLED colors selection for red and green. This is most likely not a WLED issue but I hoped someone may have experience with this issue and can shed some light on it for me. Does anyone know what this issue could be?
TIA, Bob
