I use this to connect to the SK6812 strip, and at first, it seems to work, but the color palate suddenly starts going weird. For example, when I choose blue, I get blue, but when I choose green, I get yellow. I tried to fix it by changing the color pattern, and the pattern changed, but the color was still wrong. I suspected the LED burn out, but when I did effect, all the colors seemed to appear beside whether that color was accurate or not.
Does this behavior come up with other LED strips?
i tested and it does
Okay, please more information
(Build Nr, Version, Strip Type…)
Also a screenshot of the settings for your LEDs
Thanks i solved the problem
What was the issue?
It could be helpful to others (no matter what it was).
