Macro for random solid color
Hello everyone,
Does anyone have a solution for a Macro for a random solid colour, which will not change, triggered by a button push.
I’ve split my lightstrip into 2 segments. If I push a button I would like to have a random color at the current set brightness for segment 1 and a different random color for segment 2.
I already tried effect “random color” with speed and intensives set to 0 but unfortunately the light changes over short time.
Thank you all in advance.
Bump…
I mean, the RANDOM function is already there, (R) in the color picker. Why can’t that (R) be saved like a color like a custom color?
hello, i search a solution too… If you have an idea…
Ok i find a solution, with the http request API in the preset, it work like a charm :wink:
How do you set the API command?
With the good doc :wink:
https://kno.wled.ge/interfaces/http-api/
You can write a preset with commands http-API
this is mine preset,
win&GP=0&FP=R&FX=0&R=r&G=r&B=r&A=128&SM=0&SV=0&SS=0&SP=0&S=0&S2=82.
In fact if you want you can put this preset in a playlist…
Hi thank you! I already know the API command page and I have write two simple presets for my button, One for start an effect with red color and another to reset the lights, I was searching for the “r” (random) in the API commands but not find nothing, now with your command I make a test and let you know Thank you
