Mapping don`t work with mirror
Hi!
I am using SR WLED version 0.13.2.
I have bad pixel, which I want to dissable in ledmap.json. When there is no mirror in segment setup everything works fine, but switching on mirror ignore mapping. Is there any specific ways to make mapping work with unusual segments or this is bug?
Hi ,
First you are not on latest SR , we use ledmaps a lot and tested with gaps using -1 but mainly with MM14 (This has few changes related to ledmap usage ) .Both versions are here WLED installation (wled-install.github.io)
If you test on latest SR or MM14 and you still face issue then post your exact config and ledmap.json so we could replicate .
