So I’m totally new to WLED and I’m trying to wire up some outdoor lights for my front porch for the holidays/permanent set up.
So far all the components I have are the following:
ESP32 CP2102
8-Channel Bidirectional SPI/I2C 5V/3.3V Logic Level Converter
3 in line 5A fuses
16AWG Low Voltage Landscape Wire
12v 30A Power Supply
3x BTF-LIGHTING WS2811 Addressable RGB LED Strip 16.4FT 300LED DC12V IP65
Female to Male Multicolored Dupont Wire Breadboard Jumper Ribbon Cables
The way I have it set up is the following:
Power Supply +12V to wago connector split to 5A fuse to 12v LED for each strip
Power Supply -12V to wago to all three strips, the Esp board and the Level Converter for the common ground.
ESP32 Board Level Converter
VIN (5v) - HV
3V3 (3.3v) - LV
Rx2 - LV1 - 330Ohm resistor - DIN on strip 1
I plan on having the last two strips do to mirror each other, I have the last two strips going down the banisters on each side of the stairs. I know I can split the data line coming from the end of Strip 1 to Strip 2 and 3, and to run a separate power line for each strip.
I just want to make sure my set up won’t fry anything before I turn it on.
I’d appreciate any help with my set up, suggestions to improve it. Admittedly I used ChatGPT to come up with the layout but I know it can get things wrong so I’d love to get feedback.
Thank you!
