Palette effect no longer works in wled 15.0
I have a LED strip and when I updated WLED to 15.0 the Palette effect no longer works. There is only one color instead of the moving Palette colors.
It is ok if I use wled 14.4
Thank you
Works fine for me.
There are 3 new parameters with that effect.
Looks like you activate whether you want Shift and/or Rotation as well as “Anamorphic”
Gives you much more control over how the effect works, but if you don’t select any of those options the effect doesn’t do much.
Ok, thank you.
I had problems using a 14.4 preset with Palette effect.
I’d strongly suggest you get up to V0.15.0 if you can.
There are quite a number of new effects, improvements and changes to how some of the older effects worked. If you don’t update now, I think you’ll find the changes will only get more significant as time goes on.
From my POV, it’s easier to adapt now…
Yes,
I’ve updated to 15.0 and adapted my presets with Palette effect.
It’s fine now.
Thank you
