Trying to get my playlist to work …the first 2 presets I created are set at 30 seconds each in the playlist. First one goes for 30 seconds but the second one will not change after 30 seconds. Both are set at 30 seconds and API shows 300. If I manually change the second effect timing to “30” that’s 3 seconds. A bit confused. I’ve deleted it and tried multiple times with the same outcome.
hi @Notavailable
First you shoudt not use preset 0 as in playlist shown
Then set the Transition to 0 better for Timing
What actully timing do you get for the 30sec
Good catch! I don’t have a preset 0 and the 0 should be preset 1 but it was setting it at 0. I manually changed the 0 to 1 and problem solved! Thank you kindly.
As far as actual timing with 0 set I gave up after 5 minutes or so.
That feature stopped working for me.
S
Did at first… Now don’t
