yudi83
#1
hi i want to create basic lamp for my motorcycle then i have some problem
how i can use power 3v as button triger to change mode when pressed?? (i can only triger using ground)
can u show me where parts in source code?
how i can sync 2 segment after change mode each segments? can u show where i can modify that code?
tonyno
#2
Doesn’t look like you are asking for anything that can’t be done via the UI. Check out Macros in the KB.
yudi83
#3
i have been read that macros but no solutions
yudi83
#4
problem solved by adding relay 12v to connect digital pins
